denpin 5 Report post Posted October 18, 2021 Hi, The roof on my car has faded areas, which extend to the "spoiler" section just above the rear glass, and I am looking at vinyl wrapping it as an alternative to repainting. I do not know how to loosen or remove the antenna in order to make the wrap easier. I have attached photos. Would appreciate instructions from somone in the know. Cheers! Quote Share this post Link to post Share on other sites
M3AN 4177 Report post Posted October 18, 2021 (edited) The physical antenna simply unscrews (and you can replace it with a stubby one for aesthetic reasons if you wish). The base itself needs to be unbolted from inside the car and you probably need to remove the headliner for that (PITA). It may be possible to unhook the rear of the headliner and reach in there but you'll be working blind I'd imagine. Edited October 18, 2021 by M3AN 1 Quote Share this post Link to post Share on other sites
denpin 5 Report post Posted October 19, 2021 Thanks mate. I'll probably just work the wrap over the antenna base and cut around it. Quote Share this post Link to post Share on other sites
