dave8501
E36 door panels
was wondering if u can replace the little door clips on the doors, went and got my car tinted today and the idiots have stuffed them all and none of my doors will clip on properly now..
Its easy as to replace,
you have to use a screwdriver and twist the clip out of its place. youl see what im talking about
Dealer
should be dirt cheap, clips and stuff normally are
Guest Spargo
The white clips are cheap.
You may want to glue together all the sh*t that invariably falls apart behind the E36 door, like the pockets and stuff. They are a f**king awful design.
how easy is it to take the doors off looks like ill be removing them all and replacing all the broken clips....
Guest Spargo
Unscrew the top door lock, its pretty hard to do as its smooth.
Pull away the tabs beside the handle, and unscrew the screws there, they hold the skin to the frame.
Now pull from the bottom and slide the top over the long door lock that is exposed after you unscrew that part.
Remember to unclip the tweeter!
theres a company called "R A Johnstone & Co.ltd" 5 Ryan Pl ,Manakau
[ph 09 2610336] that sell all the automotive clips [They are the suppliers to panelbeaters & motor trimmers]
