Gus 5 Report post Posted May 21, 2006 i may save attempted suicide with this one make sure both the threaded receivers on the pedal boxes are the same...if they are not swap them over...might save you an hour or two on top of having to take the pedal box out again sure is oddball, but it cant just be the one also, make sure you dont get the clutch line mixed up and throw away all your old "brake lines". has anyone got a full list of parts needed? ill make one up if requested Quote Share this post Link to post Share on other sites
Carl 3 Report post Posted May 21, 2006 Look at the maintenance g/box sticky Gus and add to the list there Quote Share this post Link to post Share on other sites
