sven007
Right Side Coupe Window not working!
It is the second time my right side window has started to play up and will not go down! The first time it did it I was to laxy to check it out and about 5 days later it started working again but now I realise if I keep leaving it, it will end up getting worse. Does anybody know how to sort these out as I hear it is quite a common problem with the 3 series.
:banghead: :banghead:
Thanks Guys :blink:
Common in all BMW's.
Does the switch still work? i.e. when you push the button, can you hear it click.
If so, the mechanism has seized. Not always permanently. You can pull the door apart and lube it up.
Otherwise, replace the mechanism.
So you know the average pricing for a new mechanism? I will first try give it a luve up after a couple of days as I just got my windows tinted and am not allowed to use the windows for 2 days! Bugger.
Thanks ^_^
Sorry forgot to mention but yes the button does work as I can hear clicking noises. Would this mean that I dont have to buy a new mechanism?
:drugs: :drugs:
:ph34r:
