topcat 11 Report post Posted June 11, 2022 came across this while the cleanup continues. used for diff coolers, but anything oil related should be fine. i had it briefly on the 537i, to scavenge the turbo oil drain . ( turbo was very low mounted, great for weight/space, not so for drainage ) $120 should be all good cant load a pic on here, i'll text it cheers Quote Share this post Link to post Share on other sites
Twistee 501 Report post Posted June 11, 2022 Might be keen, can you please flick through the model number for the pump. Thanks. Quote Share this post Link to post Share on other sites
topcat 11 Report post Posted June 11, 2022 model 40-524 1 hour ago, Twistee said: Might be keen, can you please flick through the model number for the pump. Thanks. Quote Share this post Link to post Share on other sites
