henzy 0 Report post Posted June 18, 2022 Hi is anyone knowledgeable about whether or not it is possible to swap out the ETC card rear view mirror in Japanese imported BMWs to one with the built in garage door opener? I've seen some say that its not that simple and may need coding? Thanks in advance. Quote Share this post Link to post Share on other sites
balancerider 847 Report post Posted June 18, 2022 (edited) It'll definitely need VO coding (the new mirror doesn't but the car will still think it has the ETC mirror there so will need to be removed in ISTA) but the mirror mounts are the same so should be straightforward otherwise 51162471107.PDF Edited June 18, 2022 by balancerider Quote Share this post Link to post Share on other sites
