PhilB 0 Report post Posted June 29, 2022 Hi all, new here. I recently replaced the rocker cover gasket, vanos motor gasket, vanos solonoid o rings and oil filter housing o ring on my 130i, has black plastic cover. Couple months on noticed oil seepage under engine cover. Removed cover and found rocker cover gasket leaking again and vanos solonoids leaking. Rocker gasket i got at SPR Parts , Frey brand, o rings from seal supplier. Any suggestions why it would leak so soon. I am a qualified mechanic Quote Share this post Link to post Share on other sites
elias 454 Report post Posted June 29, 2022 could be a bad quality gasket, incorrect torque spec, incorrect torquing pattern? Quote Share this post Link to post Share on other sites
NZE90 9 Report post Posted June 29, 2022 The plastic valve covers are known for warping and cracking. Quote Share this post Link to post Share on other sites
