beemwr 46 Report post Posted August 11, 2022 Yeah, e30 a rear CV joint has let go. Have e36ti rear end, so thought was l could use a rear drive-shaft from that? Quote Share this post Link to post Share on other sites
euroriffic 630 Report post Posted August 11, 2022 You can… but the ti inner cv doesn’t match the e30 diff output shaft, so will need to swap the diff outputs to suit. Not long put a e30 medium case into my compact and had to swap to e30 axles. Quote Share this post Link to post Share on other sites
