Iftikhar Khan
Oil leakage X1
My BMW X1 2011 have done only 45k and its rocker head cover gaskit / seal was cracked and leaking oil. Never expected this from BMW. Later I have come to know that its common problem with BMW. The plastic cover is also de-shaped a little. My mechanic have fixed a later model with the same issue. Why BMW don't make covers from a high temp resistant material? I have seen BMW running in +40 degree heat of Middle East but temperature in New Zealand are much lower then other hot countries.
Edited by Iftikhar Khan
spellings
  • Haha 1
There are issues with the PA66 type plastic used. Ambient outdoor temps are meaningless when engine internal temps exceed 100°C which is outside where PA66 is stable.
I agree, BMW are letting themselves down. From their perspective however it has failed outside the warranty period so there is no issue- and it is an 11 or 12 year old car.
