Toksis 3 Report post Posted December 10, 2022 My eccentric shaft sensor plug has oil on it. I need to replace the gasket. However I need to clean the oil from the connector and pins. How can I remove the oil without damaging anything? Thanks. Quote Share this post Link to post Share on other sites
jon dee 500 Report post Posted December 10, 2022 Use an electrical contact cleaner... something like this... https://www.crcindustries.com/products/qd-174-electronic-cleaner-11-wt-oz.html Cheers... Quote Share this post Link to post Share on other sites
Toksis 3 Report post Posted December 10, 2022 Thank you very much. I found this on my cabinet. I believe they are the same? https://www.supercheapauto.co.nz/p/sca-sca-electrical-contact-parts-cleaner-350g/347119.html Quote Share this post Link to post Share on other sites
