E... 61 Report post Posted May 2, 2023 NEW M20 engine rebuild/ refresh hardware. OEM + Quality Please click link below for more descriptive pictures. The following screws, nuts, and washers are included in the set: -Water branch at the rear -track cover Camshaft -Injection bar with a pressure regulator -water pump + thermostat -copper nuts of the exhaust manifold (18 pieces) -starter -servo pump and alternator, with both clamping screws -intake bridge -valve cover, with all VFL holders -additional air slider -oil sump with a stiffening plate -wheel housing -engine mounts, including the steel engine mounts of the first versions -Main sealing ring to coupling https://catuned.com/shop#!/CAtuned-Full-Hardware-Kit-Compatible-with-M20-Engine-Motor/p/313285005/category=42482014 Pickup Pukekohe or can freight. $170 Quote Share this post Link to post Share on other sites
Mad_Max 236 Report post Posted May 2, 2023 Definitely interested, any idea how much shipping would be to Invercargill? Thanks Quote Share this post Link to post Share on other sites
E... 61 Report post Posted May 2, 2023 4 minutes ago, Mad_Max said: Definitely interested, any idea how much shipping would be to Invercargill? Thanks Hey mate, I'm not exactly sure, $20 would be my best guess? Quote Share this post Link to post Share on other sites
