TonyT 48 Report post Posted June 22, 2023 A bit of a long shot but here goes. I have a 48070D code on my F31. Traction control is not working. The message is "DSC unit: Valve data for intake valve, EEPROM, perform adjustment" Code appeared after battery got low. Have now replaced the battery, but cant shift the code. My Foxwell has a DSC valve calibration routine which I have tried a few times, but which always fails. Before I go down the route of finding a replacement DSC controller (1300 Euros for a new part!), has anyone else had this problem and solved it? I'm inclined to believe it's just as likely to be a software issue as faulty hardware, but cant be sure. Would getting it on an ISTA be a useful next step? Thanks for any input. Quote Share this post Link to post Share on other sites
HELLBM 1672 Report post Posted June 22, 2023 DSC controllers available @HELLBM Quote Share this post Link to post Share on other sites
TonyT 48 Report post Posted June 22, 2023 2 minutes ago, HELLBM said: DSC controllers available @HELLBM Thank you, I'll keep that in mind. Quote Share this post Link to post Share on other sites
