hawk188
AFE power cold air intake 'coupling' part
Hi there - looking for a replacement part ( see picture which explains better ) - anyone knows where to source or have one for sale please?
Thanks!
Try emailing AFE direct and see if they will sell you the rubber gasket.  I suspect most of their resellers would want to sell you a complete unit.
You might want to think about why you have so much movement at that joint - have you replaced your engine mounts? They are a wear item on a 10+ year old car, and they are not expensive parts or a lot of labour so well worth doing.
Thanks Mr.T :) nah not replace engine mounts myself but will look into that for sure ! Have a good one !
you could make the same part with very big heat shrink. I've done it before fyi, might be easier
  • Like 1
Awesome suggestion Toast ! Thank you for the suggestion - will definitely have a go at that :)
Where did you get the large heat shrink tube from btw ?
Cheers!
Edited by hawk188
add info
