hawk188 11 Report post Posted June 29, 2023 Hi there - looking for a replacement part ( see picture which explains better ) - anyone knows where to source or have one for sale please? Thanks! Quote Share this post Link to post Share on other sites
TonyT 48 Report post Posted June 29, 2023 Try emailing AFE direct and see if they will sell you the rubber gasket. I suspect most of their resellers would want to sell you a complete unit. You might want to think about why you have so much movement at that joint - have you replaced your engine mounts? They are a wear item on a 10+ year old car, and they are not expensive parts or a lot of labour so well worth doing. Quote Share this post Link to post Share on other sites
hawk188 11 Report post Posted June 29, 2023 Thanks Mr.T nah not replace engine mounts myself but will look into that for sure ! Have a good one ! Quote Share this post Link to post Share on other sites
Toast 120 Report post Posted June 29, 2023 you could make the same part with very big heat shrink. I've done it before fyi, might be easier 1 Quote Share this post Link to post Share on other sites
hawk188 11 Report post Posted June 29, 2023 (edited) Awesome suggestion Toast ! Thank you for the suggestion - will definitely have a go at that Where did you get the large heat shrink tube from btw ? Cheers! Edited June 29, 2023 by hawk188 add info Quote Share this post Link to post Share on other sites
