arktis 58 Report post Posted August 1, 2023 It looks like I screwed up. I bought some adapter-style spacers on which the bolts are M14x1.5. I bought them a while ago, and just now noticed that the lug bolts for my wheels are a bit shorter (and 17mm v 19mm head diameter). These are the dimensions for my car (M12x1.5 bolts): I half-attached a spacer to a wheel, and it seems to fit pretty tightly. I haven't tried to attach the spacer to my hub yet because I don't have anywhere to test it until this weekend. My question is, can I still use these, or will it be an issue? The bolt pitch of the M12's are the same, and they fit snugly into the holes on the spacer. Quote Share this post Link to post Share on other sites
jon dee 500 Report post Posted August 6, 2023 Be a lot easier to understand what you have going on if you could add a photo or diagram showing the spacer in question. Does it change the PCD or number of bolts as well as be a spacer ? Do you bolt the spacer to the hub and then bolt the wheel to the spacer ? Etc... etc... Quote Share this post Link to post Share on other sites
