les 1 Report post Posted August 19, 2023 MY 330ci , failed its warrant of fitness because the third brake light "doesnt work" , so i have taken the third red brake light out of the boot lid to test it . My multi tester says its open circuit , but online this light is described as a neon light so maybe it cant be "tested" . So , im after an opinion as to what to do next before i start dismantling the loom and/or buy another light . Quote Share this post Link to post Share on other sites
Lubed 55 Report post Posted August 19, 2023 Check that you have power and earth at the high stop plug connection, if that's all good then it must be a light fault. Quote Share this post Link to post Share on other sites
les 1 Report post Posted August 19, 2023 Hi, any idea what i,d be expecting ? Cause i was thinking if its actually "neon " maybe it has a high voltage boost or something? Any idea where i might find a wiring diagram ? cheers les Quote Share this post Link to post Share on other sites
Eagle 1787 Report post Posted August 19, 2023 Its still a 12V system using a small light so doubt it anything complex. Im assuming its just a 2 pin plug going into the light? Unlikely need a wiring diagram. As above, you just want to check you have voltage at the positive wire on the plug (presumably around 12V when brake applied). Then do a continuity check from the ground wire on the plug (probably brown) to a good ground (negative battery terminal since its in the boot). Quote Share this post Link to post Share on other sites
