Vickyn
E93 Battery
Hi guys
Any advice please.
According to OEM part number, my E93 should take 70Ah 570A battery. (Varta E11)
But the battery I pulled off the car is 100Ah 845A - Size 658C.
Some research shows the Varta E44 which is a 77ah 780a fits the E93 perfectly.
Should I settle on this or should I look for a battery slightly bigger that this Varta E44?
my new 70ah was draining flat enough not to start after a few weeks. If you are driving the car every week, you should be fine. I'm guessing the Comfort Access uses power when the car is just sitting
