Murray2023 9 Report post Posted September 12, 2023 Hi Does anyone know an easy way to unclip and remove old jack points ( without access to a hoist ) so I can replace damaged ones ... I have tried using vicegrips but can not get them to hold firm enough before pushing down thanks in advance murray Quote Share this post Link to post Share on other sites
Harper 615 Report post Posted September 12, 2023 There's a slot at the top of them that you can fit a pry bar or big flat head screwdriver into and pry them out. They'll usually break on removal. Quote Share this post Link to post Share on other sites
Murray2023 9 Report post Posted September 12, 2023 Thank, I decided to try cut of the lock tabs with a multitool , but actually found that when I was going to pry off some cut bits with a screwdriver the whole thing came off 🙂 Quote Share this post Link to post Share on other sites
