PHAT 89 BEMA 0 Report post Posted June 4, 2006 hi, my central locking just stop working for some reason, i was driving along the road & my elbow pushed the lock down so all the locks went down but i didnt pull the lock back you until i stoped so when i went to jump out of the car & went to lock it with the alarm it didnt work????? i have checked all fuses, had the module out & it looks alright(it says on the cover of the module e30 coupe but my car is a 4 door, i dont know if thats the problem, was working fine until a week ago) can anybody help me My cars geting scratched up because the keys are touching the paint when i lock it every time & my key is half broken thanks Anania Quote Share this post Link to post Share on other sites
PHAT 89 BEMA 0 Report post Posted June 7, 2006 hey just checked my central locking module & i tested it with a power tester & there wasnt any power to none of the wirers????? any one know why this could be. & when i was looking at the Central Locking Module i seen a relay plug but there was no relay, is this relay plug for the central locking? Quote Share this post Link to post Share on other sites
nz320i 0 Report post Posted June 7, 2006 the fuse for central locking is fuse no.27 and its a 30amp, have other things stopped going since? also i think it would have a relay, can you hear anything click when you push the door lock pins up and down on the drivers door? Ive had heaps of probs with locking and in the end i replaced the lot with a cheap after market kit and it works fine..just annoying knowing its not factory! Thanks Quote Share this post Link to post Share on other sites
PHAT 89 BEMA 0 Report post Posted June 7, 2006 hi yes i have checked all fuse & they are all ok. i checked to see if there was any power to the relay plug but there was no power there to? the relays not there when i checked but i think it may have fallin out. the only thing that stoped working it the central locking. ill check & see if i can hear any think when i push the lock up & down. how much was the after market central locking kit? & was it much work installing it? Quote Share this post Link to post Share on other sites
nz320i 0 Report post Posted June 8, 2006 sooo easy to install the after market one cos the motors were the same size as the bimmer ones, was 30bucks!! thats only for 2 doors though, you might want to add extra motor in the boot, i didnt bother as i never use the boot.. Quote Share this post Link to post Share on other sites
PHAT 89 BEMA 0 Report post Posted June 8, 2006 wheres that off??? do you just swop the motors over? dont you have to change the wirering or anythink. Quote Share this post Link to post Share on other sites
