TronSpec
pre facelift manual steering racks
I have a 89 face lift e30 with a f..cked left rack end. I had pulled my powersteering pump and belt off and had being running the power rack as a manual with the hydralic lines plumbed back into it self for last 4mths. It's warrent time and cause I like the feeling of non power assit and my rack ends had it I am looking into buying a manual rack off a non face lift model e30. :huh: has anybody had any experience with this? can it be done?
Thanks
Mrhamwallet
A pre FL rack will fit as long as you use the steering shaft for that rack as well. Why do you want to use a pre FL rack anyway? They are all 19 or more years old now. I would try and get a manual rack from the newest car I could find if I were you. Try and get one from a 90-91 316
Thanks man
I thought pre facelifts were the only ones to still have manual racks.
Sorry to jack your post, but is it just the coupling that needs to be swapped over or the whole shaft? I was under the impression that the small shaft on the couplings were what changed between the power and non-power steer, or is that not the case?
