GreyGhost 3 Report post Posted October 15, 2023 Hi All, My E70 40D (N57 engine) has a tiny oil leak from the rocker cover gasket. I put it in the shop to get the gasket replaced but after much trying the shop gave up because they couldn't remove a couple of the injectors. Any tips or tricks for this? Is it really necessary? Any help appreciated. Cheers Nick Quote Share this post Link to post Share on other sites
Cammsport 391 Report post Posted October 16, 2023 Unfortunately it is necessary, and a pain in the a**. Likely from leaking injector seals. The best way is to do multiple soaks of some form of penetrant (not too much) and hope some hot/cold cycles free them up. If no success, you'll have to have a crack with a slide hammer hammer. See below. DO NOT DAMAGE THE INJECTOR! Very expensive. 1 Quote Share this post Link to post Share on other sites
