Kodachrome
Bremi (bmw m60) ignition coil rubber boot
Has anyone got any bmw (bremi is oem) ignition coil pack rubber boots (or a bad or used coil I can take the boot off)? Doing the rocker cover gaskets and spark plugs and found one of the coil pack's rubber boot to be torn at the end!
Coil and boot looks like this: https://www.bimmerworld.com/Engine/Ignition/Coil-Pack-12-13-9-066-468.html
No longer required, just bought a set of used coils as a backup for my main.
