Jono51 61 Report post Posted April 22, 2024 (edited) 2008 335i NZ New 130,000 km approx $15900 location Marton , Rangitikei 021651591 For sale is our meticulously maintained 335i Convertible, a New Zealand New Motorsport edition. This vehicle has only covered a low 130,000kms and comes with a VTNZ warrant and registration. This car has undergone extensive mechanical refurbishment and maintenance to ensure it's in top-notch condition. Both of the turbo cores have been overhauled, and the inlets have been walnut media blasted for optimal performance. A new rocker cover has been installed, and the PCV system has been modified, including the runners blanked to prevent typical N54 issues of oiling up inlets. To ensure the best possible performance, we've installed twin catch cans for both high and low sides. The transmission has been thoroughly serviced - the mechatronic unit has been removed, new case and bridge seals have been fitted, and a new pan has been installed. Also performed a full power flush with genuine ZF oil. The engine has been given a thorough inspection, with all Cam ledges removed and checked. Cam ledge seals have been upgraded, from the steel styled, to the superseded PTFE OEM BMW replacements to prevent ledge wear. All 24 valve guide seals have been replaced to ensure piece of mind . During our ownership, we've also fitted new Hankook Tyres and installed a new battery Various coolant pipes, power steer pulley and tensioner Its also worth noting this car has already been modified with Catless downpipes and Coby muffler system. This 335i Convertible is the hardtop type Convertible as opposed to the conventional rag top and it's water tight. I've extensively photographed the repairs done to this vehicle and they are available for the new owner, There is no money owing on this vehicle and a vehicle check has been provided in the Auction. To clarify the previous owner didn't keep the registration current, and the plates lapsed and subsequently has had it re-registered. A factory recall is up-to-date that has been completed by BMW .We are currently using the vehicle over summer and the mileage may increase slightly. Edited April 22, 2024 by Jono51 2 Quote Share this post Link to post Share on other sites
Olaf 3426 Report post Posted April 23, 2024 buy a silk scarf for your wife or girlfriend, buy this, get away for a long weekend with the top down. go for it! 1 Quote Share this post Link to post Share on other sites
