bmwerks 2 Report post Posted April 24, 2024 Hi All Does anyone know if a e46 318i GM auto gearbox internals are different to a e46 330D GM auto gearbox? I am contemplating a solution to a stuffed gearbox - one of which is swapping the bellhousing of a more readily available 318i gearbox. TIA Quote Share this post Link to post Share on other sites
euroriffic 630 Report post Posted April 24, 2024 7 hours ago, bmwerks said: Hi All Does anyone know if a e46 318i GM auto gearbox internals are different to a e46 330D GM auto gearbox? I am contemplating a solution to a stuffed gearbox - one of which is swapping the bellhousing of a more readily available 318i gearbox. TIA I have gone though this same thing but with the m54 and m57 e53 x5’s gm 5 speed auto, but everything I found was pretty much hearsay, so no concrete evidence, apart from different gear ratios. Otherwise there was a full manual conversion on trademe with a six speed box Quote Share this post Link to post Share on other sites
