The Bimmer 12 Report post Posted August 21, 2024 Selling Feature Installer Codes for DIY User Feature Installer is a professional application for Coding through the Cloud system for BMW/Mini cars with a program design that is easy to use and a suite of functions for BMW NBT/EVO4/EVO5&6 head units to generate USB loaded BIN files or Generate Codes to enable functions such as CarPlay, Video In Motion,Region Change as well as unlocking limitations in the system of BMW and Mini Headunits and a lot more for advanced user.The tool is also designed to provide better support for DIY Activation.If you need feature codes please contact me. Selling cheap price for Bimmersport Members Feature Installer Support: -FSC Retrofit Packs(NBT,NBTEvo,EntryNav) -Maps Activation Code(NBT,NBTId4,Route) -Region Change(NBT,NBTEvo) -CarPlay Full Screen/Split Screen -Install BlackScreen / Region Unlock -Enable VO Coding Fix -Enable VIM – Video in Motion -Virginize EVO – Clear V850 -EVO and EntryNav2 Remove Component Protection -Carplay connect fix for X/Y versions -ID4 to ID6 FSC Pack -Open/Close SSH -Clear sweet and many more All you need is a windows laptop,enet cable and good internet connection.I will provide to you the download link for Feature Installer App.Other jobs requires Esys or Launcher to complete. You must know what you’re doing and what to do with the files.All further support will have to be paid if you will run in some problem that are not related. You will receive a different Feature Installer code for every option that you select.Feature Code is tied to your car’s VIN. I offer no warranty, liability, responsibility or offer compensation should anything go wrong.If you don't know how this things works or what it will do, STOP!!!So it is you to decide if you want to take a risk. 2 2 Quote Share this post Link to post Share on other sites
TheoneLT83 0 Report post Posted January 21 How much for full all code? Quote Share this post Link to post Share on other sites
The Bimmer 12 Report post Posted January 22 13 hours ago, TheoneLT83 said: How much for full all code? Hi,what job you are trying to accomplish Quote Share this post Link to post Share on other sites
