MattA 165 Report post Posted November 15, 2024 (edited) SOLD - For sale - BMW M60/M62 centrifugal supercharger setup. Purchased Dec 2021, but circumstances have changed and now have other priorities. Details below are from the original owner and his setup. Made 406whp on original M60B44 setup with water/methanol injection at 5psi with belt slip at 5.5k rpm. Further modifications made to setup by the original owner, but didn't go back to dyno. With other supporting mods was guesstimated to be about 450-470whp Will include the following; Powerdyne BD10 Mounting bracket Upgraded one piece billet impeller shaft Upgraded input shaft pulley Upgraded internal drive belt Drilled case for improved internal cooling Custom toothed crank pulley Custom toothed supercharger pulley 6rib crank pulley 6rib supercharger pulley 6rib upgraded smaller pulley with grip enhancer Several drive belts included Spare impeller and drive pulley bearings 1x GFB Mach2 blow off valve 1x Scarles blow off valve 1x bosch diverter valve 2x tensioners AEM pod filter Blower to Intake piping Supercharger inlet piping Several silicone hoses/bends to suit Numerous mounting bolts/washers/nuts Will require the following; Modified ASC/Cruise control intake elbow or custom connection to throttle body. Custom ECU tune - can help with a Link G4+ Xtreme tune. Some users in the USA have included a resistor inline with their MAF setup to adjust the reading on factory ECU. Lots of info online about this A couple of silicone hoses/bends to suit your application Some vacuum lines to suit your application $6,500 ono I may have forgotten some items. Reach out with any questions, happy to chat and share any info I can. Cheers Matt Edited December 4, 2024 by MattA Sold 2 Quote Share this post Link to post Share on other sites
Autobahn 22 Report post Posted November 16, 2024 Very cool! I definitely don't neeeeed this but boy would it be a nice upgrade. GLWS! 1 Quote Share this post Link to post Share on other sites
MattA 165 Report post Posted November 18, 2024 On 11/16/2024 at 11:29 PM, Autobahn said: Very cool! I definitely don't neeeeed this but boy would it be a nice upgrade. GLWS! If we only drove what we need, there'd be no cool old school BMW's, or anything else... You probably need it 😄 Quote Share this post Link to post Share on other sites
BMTHUG 1111 Report post Posted November 21, 2024 this is soooo sick bro! 1 Quote Share this post Link to post Share on other sites
MattA 165 Report post Posted December 4, 2024 Sold 1 Quote Share this post Link to post Share on other sites
