denpin 5 Report post Posted December 13, 2024 Hi, I have been trawling thru various forums looking for a way to pull the complete VO. The VO which comes up when I use NCS Expert F1 and F3 is apparently incomplete. I would like to do the following: 1) change the country code on the VO from Japan to New Zealand. 2) Check if the vehicle is equipped with rear view camera functionality. There is a physical camera installed, but it does not engage or dispaly on the screen. Quote Share this post Link to post Share on other sites
exextatic 173 Report post Posted December 13, 2024 If you're not confident with the VO displayed in NCS Expert, you can use an online VIN decoder tool (e.g. MDecoder) to get the original VO for the car. The reversing camera pictured is aftermarket and won't show up in the VO. Aftermarket units typically intercept the signal going to the CID to show the camera output; this method is transparent to the vehicle's modules. Quote Share this post Link to post Share on other sites
