joymax 0 Report post Posted April 21 Hello eveyone, Joymax is here. I have question, regarding maybe somone has a answer. i have bmw e90 3 serie sedan, pre lci model. ( i builded everything from zero) i never had electric seats inside, and there is the thing. i just installed seats from f82 m4 cs, and wiring has to be done. i looked over forums. my question is, where do i start? do i need extra moduls, or whatsever, please help, thanks Quote Share this post Link to post Share on other sites
M3AN 4155 Report post Posted April 21 Nice seats! You have some work ahead of you though, it's not just the electric movement, you'll also need to deal with the airbags and belt tensioners. I'd start with working out how to get your old seats electrified, that will cover the modules, wiring, and coding, this might be a helpful thread in that regard: https://www.e90post.com/forums/showthread.php?t=480313 Once you understand that then you may just need to re-pin some of the wires to support the new seats. Some people with E92 M3's have done the conversion so you should be able to find any pin conversion requirements. Good luck, keep us posted. Quote Share this post Link to post Share on other sites
