zac_ 0 Report post Posted July 2 Recently got a 130i and am looking to install some coilovers and lower the car a bit. How much can I lower the car without needing toe or camber arms. If I do need aftermarket arms, who stocks them in NZ Quote Share this post Link to post Share on other sites
M3AN 4161 Report post Posted July 3 (edited) You can get some more camber by using M3 front arms and completing the camber pin mod, that combination will give you an extra degree or so - both done in these pictures. On coilovers, lowered no rubbing, 18's, e36 offsets, 255r/225f: Coilover, no rubbing, 18's, e87 offsets, 255r/225f: Could probably go another 10mm lower f/r with the e87 offsets. Edited July 3 by M3AN Quote Share this post Link to post Share on other sites
zac_ 0 Report post Posted July 3 Do you know how much camber front and rear you can get with the factory arms? No issues with not enough adjustment for toe in the rear with factory arms? Quote Share this post Link to post Share on other sites
M3AN 4161 Report post Posted July 3 (edited) Factory front arms and camber pin mod is around +0.2-0.3 degrees. There's no other adjust-ability with stock parts. Rear is also very little with eccentric bolts, but you don't want a lot of rear camber if you want the car to work properly, it's RWD after all. Edit: I see you asked about rear toe, not rear camber, duh on me. Rear toe is easy, you only need either zero or a tiny bit of in right? Stock parts can easily accommodate that. Edited July 3 by M3AN Quote Share this post Link to post Share on other sites
zac_ 0 Report post Posted July 4 (edited) I thought lowering the car changes the toe so I was mostly wondering if I lower the car will there be enough adjustment in the factory toe arms to get 0 toe. I might just look into getting aftermarket camber and toe arms if I get coilovers then will have to get the car certed. Do your front coilovers have camber adjustment on them or you need separate camber plates? Edited July 4 by zac_ Quote Share this post Link to post Share on other sites
M3AN 4161 Report post Posted July 4 You're correct that ride height changes geometry but I have run both zero toe on this car F/R and now my preferred geometry which is F-ve and R+ve, all done with factory arms, bolts, etc. I do not have adjustable top mounts at the front, not necessary for my purposes (fast street). There will certainly be enough adjustment with the factory bits for 0* toe, front or rear. Quote Share this post Link to post Share on other sites
zac_ 0 Report post Posted July 4 I'm looking at ordering some aftermarket toe and camber arms for the rear and they come in either M series or non M. From looking up the VIN number my car seems to have M-Sports Suspension package, does this mean I will need M series arms or is M series and M sport a different thing? Quote Share this post Link to post Share on other sites
M3AN 4161 Report post Posted July 5 Not sure to be honest, that will depend on the manufacturer - I'd reach out to either the manufacturer or the reseller to confirm 100% before ordering. Quote Share this post Link to post Share on other sites
