Toksis
Leak rear left vcg and spark plug tube leak at cylinder 4 even new vcg cover and tube
Ok i replaced VCG and spark plug pipe on my cylinder 4 of my n46 e90. Torque to 10nm. However it still leak. Any advice on how to fix this?
The plastic valve cover itself could be cracked, seems to be quite a common occurrence. Worth checking it over thoroughly every time it's off, cracks can be hard to spot being black plastic and caked in gunk.
is there a way to fix it if it is cracked? The spark plug pipe too is leaking little oil. Even I replaced the spark plug pipe in cylinder 4. I thought maybe tighten it more than 10nm?
I wouldn't tighten it more than that, those threads are really easy to strip out. Wouldn't mess around repairing the valve cover either, just straight replace. Should be cheap enough from Pick-A-Part or similar.
