buzzlightyear
325i main wiring harness plug
i have just converted my 2litre E30 prefacelift into a 2.5. i had to get new box new flywheel from germany been a real bit of a mess really :banghead: . everything in but there is one thing left and im hoping someone knows a bit about it cause i have no idea... :wacko:
on the 2.5 it has a round main harness plug and on my 85 320i it has a square plug. just wondering is it possible to mate them up, could anyone please supply me with a wiring diagram?
any help be really appreciated!
Motronic Engine Plug (round) L-jet Car plug (square)
Pin 1 BL Pin 1 BL
Pin 2 BL-V Pin 2 BL-Y
Pin 4 BR-WH Pin 4 BR-V
Pin 5 BR-GN Pin 16 BK-BR
Pin 7 GN Pin 10 GN
Pin 10 BL-WH Pin 15 V-GR
Pin 11 WH-BL Pin 17 WH-BL
Pin 13 GN-V Pin 7 V-R
Pin 18 BK-YW Pin 8 BK-YW
The colour codes above may not be the exactly same as on your car or engine (some of mine were different) depending on the year but they will usually be pretty close. If you are lucky you may find the wiring colours at each plug are the same and only the plug shape is different. Some of the wire colours changed over years and some wiring diagrams don't agree with one another (eg the Haynes and Bently manuals dont agree on colours, I even have two Haynes manuals that cover the same models, that are published in different years and they don't agree either) All the manuals do however agree on the pin numbers
Hey mate I pm'd you ,I've got a plug here that you can have that may make life easier for you let me know if you want it
cheers
Darren
how much did it cost you to get the parts from Germany. What was the freight like and how long did it take to get here.
