westy
Late e30 manual starter motor
Im looking for an e30 starter motor, preferably from a facelift.
A stuffed one with a good pinion would be ideal,otherwise a cheapy would be sweet.
Thank you.
how bout one from an m40?
cheers
Darren0211645663
it might work, if its from a manual...it seems to be more the pinion tooth spacing difference between auto and manual
Yeah, its a fine toothed one,teeth are closer together for the flywheel that has approx 139 teeth. :D
Will call tomorrow Darren.
Hi, you guys sure that manual and auto are different? I've just dropped the ring gear from my auto on top of the manual and they match perfectly, I've got both in pieces at the moment, in the middle of race car build, the teeth numbers and size are the same.
