sadida20 0 Report post Posted July 17, 2006 Hey guys got a new roundel for the 323. i went to take the old front one off and it didnt really come off to well. it came off but left what looked like some glue on the bonnet and no holes were visable for the new roundel to go into. whats the best way to fix this and put new roundel on. thanks Quote Share this post Link to post Share on other sites
my_e36 43 Report post Posted July 17, 2006 If you had successfully got the whole roundel off, you can see the paint work and two holes to plug the new one into. I suspect you've only taken the top part of the roundel off. Quote Share this post Link to post Share on other sites
sadida20 0 Report post Posted July 17, 2006 If you had successfully got the whole roundel off, you can see the paint work and two holes to plug the new one into. I suspect you've only taken the top part of the roundel off. yeah looks that way. what to do now? Quote Share this post Link to post Share on other sites
Silver Fox 43 Report post Posted July 17, 2006 Hi, if the silver plastic piece is still on, carefully prise it off, it's only held on by the 2 lugs, use a screwdriver or the like, cover the end with a rag, and slip it under from the side, not the top or bottom, and gently lift. It should come away, you can then fit your new one. Would suggest a small bit of sealant or the like under your new one to help it stay there. Quote Share this post Link to post Share on other sites
Guest Andrew Report post Posted July 17, 2006 Get a small flathead screwdriver under the whole roundel - (using something soft to protect paint) and wedge it off. Quote Share this post Link to post Share on other sites
E30SIX 0 Report post Posted July 22, 2006 (edited) The link below will answer all your questions. Click here Edited July 22, 2006 by E30SIX Quote Share this post Link to post Share on other sites
