conrod
BMW F1 Turbo
just a quick question conrad...why put the Throttle body in front of the turbo?
Good question! It is not really the throttle body as such. (If you study the pics real close you will see it has ITB's close to the head) It is there to stop the turbo from stalling when the throttle is snapped shut, when tends to snap the turbine shaft on highly boosted engines. it works in conjunction with the normal throttle butterflies, when the throttle is released, it closes the mouth of the turbo, preventing it from dragging in more air, so you don't get the big pressure buildup between the turbo and throttle butterflies.Much the same effect as running a dump valve, only on this setup, the turbo runs in a sort of semi vacuum, with the butterfly on the compressor inlet blocking any air from entering when the throttle is closed.
controlled by vacuum or engine management? didnt study pics close, just noticed it quick!
very clever
1300hp. madness.
makes you wonder what sort of hp they would be making nowadays if they didn't have all the regulations (no FI) etc.
Edited by petone
That's so badass!!!!
What about the 1960's F1 car. Haha Saftey was obviously 3rd to speed and power
