savvi
sway bars 325i e30
:wacko: im after a place to buy upgraded sway bars and air flow heat shields, any help wil b great
Guest Andrew
I like the sway bars from turnermotorsport.com -
Bear in mind they are designed to match thier springs/shocks however.
Heat sheilds (for a pod filter I assume) - easiest to make yourself/
mild upgrade is the rear to the mtech 14.5 from 12mm....tightens it up a little, makes it less understeery. M3 ones are made for 4cyl, so have a lighter front
M3 front bar is smaller than your 325i front bar but only becuase it uses different mounting points so it has a larger effect. Could be wrong on this stuff but anyway...M3 is 14.5mm in the rear as well, so same size as M-tech, tourings (wagons) and maybe cabs also have bigger rear bars.
I've got a 325i rear bar and standard bar in the front for my 4 cyl and its pretty nicely balanced.
You can get whiteline bars from SAS, anyone had any experience with them?
Guest Andrew
what about m3 sway bars would they fit, i also heard that you have 2 reinforce the sway bar links otherwise they just snap off
They rear trailing arm swaybar mounting tabs are badly designed (for use with very stiff sways) - they bend. Turners do a reinforcement kit - however its just two triangle pieces of steel.
