savvi 0 Report post Posted August 6, 2006 im after a place to buy upgraded sway bars and air flow heat shields, any help wil b great Quote Share this post Link to post Share on other sites
Guest Andrew Report post Posted August 6, 2006 I like the sway bars from turnermotorsport.com - Bear in mind they are designed to match thier springs/shocks however. Heat sheilds (for a pod filter I assume) - easiest to make yourself/ Quote Share this post Link to post Share on other sites
Guest Andrew Report post Posted August 6, 2006 http://www.turnermotorsport.com/html/detai...RODUCT_ID=52010 Would be ideal Quote Share this post Link to post Share on other sites
savvi 0 Report post Posted August 7, 2006 (edited) http://www.turnermotorsport.com/html/detai...RODUCT_ID=52010 Would be ideal what about m3 sway bars would they fit, i also heard that you have 2 reinforce the sway bar links otherwise they just snap off Edited August 7, 2006 by savini Quote Share this post Link to post Share on other sites
Gus 5 Report post Posted August 7, 2006 mild upgrade is the rear to the mtech 14.5 from 12mm....tightens it up a little, makes it less understeery. M3 ones are made for 4cyl, so have a lighter front Quote Share this post Link to post Share on other sites
petone 0 Report post Posted August 7, 2006 M3 front bar is smaller than your 325i front bar but only becuase it uses different mounting points so it has a larger effect. Could be wrong on this stuff but anyway...M3 is 14.5mm in the rear as well, so same size as M-tech, tourings (wagons) and maybe cabs also have bigger rear bars. I've got a 325i rear bar and standard bar in the front for my 4 cyl and its pretty nicely balanced. You can get whiteline bars from SAS, anyone had any experience with them? Quote Share this post Link to post Share on other sites
Guest Andrew Report post Posted August 7, 2006 what about m3 sway bars would they fit, i also heard that you have 2 reinforce the sway bar links otherwise they just snap off They rear trailing arm swaybar mounting tabs are badly designed (for use with very stiff sways) - they bend. Turners do a reinforcement kit - however its just two triangle pieces of steel. Quote Share this post Link to post Share on other sites
