savvi
325 e30 dash board help
i need to know if if i can take the plastic panel that sits just above steering column and runs parallel with the lights without breakn it so i can paint it and what paint is appropriate for plastic cheers B)
The plastic panel above the steering column can be removed. It's held on with two nuts at the back. If memories right ya can get to it by taking off the under dash panel.
spot on - two thumbscrews behind the panel thatyou access from underneath by first removing the under dash panel. Once it is off you can unscrew the rest of the plastic trim and instrument cluster itself.
