Docile
transmission fluid
Hi guys,
Along the same lines, I too have a question...
I have a recently bought a '95 BMW 525i (think it's a VANOS M50B25 engine), a jap import, comes with a JATCO 5-speed auto trans (the label reads JR502E and then GB010 and 4821152YOE) - changing 2nd to 3rd is a bit jerky so I'm thinking of changing the ATF and filter (can't tell how bad/old the fluid since there's no dipstick).
Any ideea what ATF type I should use?
Alternativelly, could anyone recommend a trustworthy/fair priced AT service specialist in Christchurch?
Cheers,
Alex
Edited by alex_c
  alex_c said:
Hi guys,
Cheers,
Alex
Use the same oil G3 full synthetic
Hi Glenn, thanks for the info. A couple more questions, if possible:
- How can I make sure G3 is OK with the ATF already in (as I understand I won't be able to drain more than 3-4 litres out of the total 8?) - what brand would be better?
- Is there any way to reset transmission program without using a specialised tool?
Cheers,
Alex
Cheers,
Alex
Best you give me a call
You mean to say that even on a tranny fluid change I need to reset the ECU like on engine oil change?
During the weekend I did the fluid change and pumped about 6.5Ltrs when another guy was in the car going through the gears from R-n-d-4-3-2 on interval of 30 sec each.
After the change the gears are smoother and everything is ok so far.
  alex_c said:
Hi guys,
Correction: the jerky upshift is in fact between 1st and 2nd (I thought it was starting in the 2dn gear, but that only happens when I put it in * mode, which is fine, slow start but no silly 1st/2nd jerking).
Anyway, I've booked it with the Aceomatic service shop in Addington (Clearance St) for next Tue - anyone been there before, any issues?
Any other AT service specialist in Chch that you guys recommend?
So, I had the Aceomatic guy scan both the engine and transmission - no faults reported by the electronics.
He says he'd take the transmission out and start taking it apart, trying to find and fix the problem, but that can get expensive - anywhere between $1500 (best case scenarion when only a few minor parts need to be replaced) to $3500+ (in case the transmission has to be overhauled).
Unfortunatelly I'm not prepared to invest that kind of money at this stage, so I'm thinking of changing the ATF myself (with the help of a mechanic friend).
Glenn, what brand was that G3 Full Syntethic ATF you recommended?
Cheers,
Alex
We use Elf.. but any well branded oil will be fine
  alex_c said:
Thanks Glenn, something like this: http://www.partsquip.com/files/imagecache/...20Oil%20050.jpg ? How about the filter and trans pan seal?
http://www.penrite.com.au/products.php?id_...;id_products=37
http://www.penrite.com.au/products.php?id_...;id_products=33
Also if the jerky shift is due to wear you could try this too, it's not expensive and won't hurt.
http://www.lubegard.com/automotive/trans_shudder_fixx.html
  Docile said:
ok im a bit confused about my tran pan.
its not like the ones for a A5S310Z that ive seen in service manuals and online. and also it dont have any stickers to say which fluid to put in.
Posted Image
picture taken looking back.
i felt around the pan to see if there are any other plugs, nada.. its just those 2.
Hi. I am no expert, but from experience with mine (1997 323i) I would say the plug on the left (with the Allen key) is the Filler - it in more recessed, hence higher. And the plug on the right looks like the drain plug. Although recessed, it is probably lower than the Filler, which is 'collared'.
PS, looks like you have had a couple of scrapes on your underbelly...
See my pics on http://www.bimmersport.co.nz/forums/index....showtopic=36701 - Actually, when I look again, it is exactly like mine...
Edited by Genka
  bekker said:
Blast! That "Trans Shudder fix" page has gone.
Is it the same as this one?
http://www.lubegard.com/~/C-230/Dr.+Tranny...nt+Shudder+Fixx
It claims to be a "...concentrated friction modifier formulated specifically for INSTANTLY eliminating torque converter lock-up shudder"
Yeah, right...
