LemonHunter
E34 540i Coolant Type/Qty
What brand(s) Of Antifreeze are recommended for the Bimmers?
I generally use Fuchs in my Jappas, i think they are of German Origin so should have the goods?
And secondly, how much coolant is likly to be in the system? Im guessing well over 5L, massive Radiator...
I havent had much experience with coolant.
However when I did my all-alloy engine Honda, my mechanic recommended this one from Valvoline.
http://www.valvoline.com.au/products.cfm?m...0Boil%20Coolant
Seems like a very good quality coolant, but not the cheapest.
Should be readily available.
Check the ratio too. For my BM they recommend a 60/40% water coolant ratio.
Hope this helps.
Well, after consulting the owners handbook (forgot about that doh!)
12.5L is the cooling system capacity :blink:
Handbooks rock.
