KeithAndrew 0 Report post Posted September 5, 2006 (edited) :Bad Design: Has anyone else had a problem with the wiring loom wearing through where the boot hinge is rubbing on the loom between the two rubber grommets on their Z3 ? Although it a 1999 car its only done 33000kms so the boot hasnt been used very much.I discovered this when I found the light in the boot not working and the central locking blew the fuse. On close inspection there was a small hole in the outside sheath so when I had a closer look after freeing the cable from the plastic retainer 4 of the seven or eight wires were broken due to a part of the hinge rubbing on the cable. Edited September 5, 2006 by Z3Man Quote Share this post Link to post Share on other sites
BM WORLD 1296 Report post Posted September 5, 2006 :Bad Design: Has anyone else had a problem with the wiring loom wearing through where the boot hinge is rubbing on the loom between the two rubber grommets on their Z3 ? Although it a 1999 car its only done 33000kms so the boot hasnt been used very much.I discovered this when I found the light in the boot not working and the central locking blew the fuse. On close inspection there was a small hole in the outside sheath so when I had a closer look after freeing the cable from the plastic retainer 4 of the seven or eight wires were broken due to a part of the hinge rubbing on the cable.i had this problem with a 1991 318i had to replace wirring from another car .soldered it in to car loom . i have a rear end from a z3 if you need wiring , only done 16,000km 021433600 Quote Share this post Link to post Share on other sites
KeithAndrew 0 Report post Posted September 5, 2006 i had this problem with a 1991 318i had to replace wirring from another car . soldered it in to car loom . i have a rear end from a z3 if you need wiring , only done 16,000km 021433600 ThanksWaiting for a reply from BMW NZ as to fix but may call when Ive heard from them Quote Share this post Link to post Share on other sites
