jochen
Anyone have an E39 with a factory alarm in it?
Hi Ems (?),
What year is your car?
Is it NZ-New or ex-Japan or ex-Singapore?
Do your indicators flash when you lock/unlock the car?
Have you every tested the alarm to see how it goes off?
Does it sound the horn as well as siren?
Ta, Jochen
Jochen - my E39 does.
What year is your car? - 1996
Is it NZ-New or ex-Japan or ex-Singapore? - NZ new
Do your indicators flash when you lock/unlock the car? - when I lock it only (not when unlock)
Have you every tested the alarm to see how it goes off? - only by accident
Does it sound the horn as well as siren? - just the siren (I think -not sure)
The first time the alarm went off was when a friend was wandering around by the parked car with a portable phone from his house. That triggered it. The other time, I left my dogs in my car while I went into a shop. I forgot about the internal motion sensor. Off she went.
Cheers,
Rog
I dont know if your aware Roj but on my e38 if I press the remote once to lock the car then press it a second time after its looked it sets the alarm but disarms the interior motion sensors.
I assume the e39 is the same.
Hi Ems (?), Yep im Ems
What year is your car? 1996
Is it NZ-New or ex-Japan or ex-Singapore? NZ New
Do your indicators flash when you lock/unlock the car? Only when I lock it
Have you every tested the alarm to see how it goes off? No, though it has gone off once.Just siren.
Does it sound the horn as well as siren? I'm not sure. Pretty sure it was just a siren.
Ta, Jochen
Edited by BMW POWER
Hi Jazzbass,
I am trying to nut out why my car doesn't flash the indicators when I lock it.
I may be forced to have the tilt sensor and the ultrasonic sensor - I thought i might be able to ignore them
I'll try and find the right bits on ebay etc and try it out.
Jochen
Jochen, when I use the remote infrared keylock to lock my 99 E39 there is no noise or light flash, if you find out how to turn this on I would be interested in knowing
Edited by Huttey
To turn it on:
Go to BMW dealer, connect DIS
Run the retro-fit alarm coding for your car
Enable light flash for lock / unlock as desired.
May or may not work - didn't flash lights on my car, maybe because it wants the extra devices connected as welll (tile sensor, movement sensor)
Jochen
