320SHKBTE
Sub Problem
Ok, first my angel eyes now my sub :huh: , it went off a couple of days ago and blew the big fuse to the battery from the amp, so i replaced it and it blew again, and again, so i undid it all, changed the wires, but now when i turn it on it goes, THUD, then the sub sticks, like upwards <_< ...the fuse dosent blow, but the sub dosent work or anything, is my amp buggered?
How dodge is your wiring? Can you hit us with your audio specs incl. cabling?
sounds like amp problem, the subs sticking like that because its got a constant source of power running to it, just like if you put your sub straight to a battery, sounds like youve fried somthing in your amp, just my geuss as i cant see your system.
chuck us your amp and sub specs, including wire gauges and fuse sizes.
