keen 6 Report post Posted October 10, 2006 the reverse lights now don't go.They were getting to be trouble over time but I could move the gearlever around and they would come on but not any more.someone know what to do? or had the same problem? The car is 1989 year Quote Share this post Link to post Share on other sites
hotwire 352 Report post Posted October 11, 2006 Probably the switch on the gearbox/trans, 2 wires to switch, in reverse, key on, check for power to then through the switch. If none to then check fuse, if to & not going through - replace the switch, if power on both sides - check wiring beyond/ bulbs / connections. Cheers Quote Share this post Link to post Share on other sites
keen 6 Report post Posted October 11, 2006 thanks for that I will try those things on the weekend.they are not too hard for me to do thanks Ken Quote Share this post Link to post Share on other sites
