E30-323ti 66 Report post Posted March 16, 2004 As the topic states, must have for regular track abusers. These have been certified for road use on my E30, so on any other E30 it will not be a problem. They are a bolt-on upgrade. Here are the specs: 290x26mm 2 piece rotors Evo 4, 2 piston sliding calipers Caliper mounting brackets and mounting bolts Note: A 16" wheel is the smallest that will fit over these brakes!! $700 ono Here are some pics Quote Share this post Link to post Share on other sites
E30-323ti 66 Report post Posted March 16, 2004 and the mounting bracket: Quote Share this post Link to post Share on other sites
Guest Spargo Report post Posted March 26, 2004 Any E30? Perhaps an 318is? What about ABS? Affected? And I assume the pad wear sensor is rendered useless? Quote Share this post Link to post Share on other sites
E30-323ti 66 Report post Posted March 26, 2004 Yip any E30 except M3's. ABS will work fine, pad wear will not work, could prolly make it work though!! Quote Share this post Link to post Share on other sites
OLLIE 27 Report post Posted April 18, 2004 glenn do you still have these? if so hold onto them something i would be interested in in the future if i decide to go turbo Quote Share this post Link to post Share on other sites
