speedyg 19 Report post Posted November 28, 2006 Looking at replacing the viscous clutch, sounds pretty easy in the bentley manual. I'm guessing you have to take the fan shroud off and then undo the nut (reverse thread) from underneath with a 32mm spanner. Any hassles I am likely to encounter? Quote Share this post Link to post Share on other sites
hotwire 352 Report post Posted November 28, 2006 No, Your'e onto it, with the right spanner - needs to be pretty thin to get between hub & water pipe (if motronic) remember reverse thread then give spanner a sharp twack with a hammer. Obviously reverse to refit. Cheers Grant Quote Share this post Link to post Share on other sites
