blk320i 0 Report post Posted February 11, 2007 (edited) need a window wiper valve for my e30 as mine is clogged up. part 15 below http://www.realoem.com/bmw/showparts.do?mo...hg=61&fg=45 thanks Edited February 11, 2007 by blk320i Quote Share this post Link to post Share on other sites
Palazzo 533 Report post Posted February 11, 2007 They're cheap as at the dealers mate, can't remeber how much, I didn't even bother keeping the receipt. Quote Share this post Link to post Share on other sites
Gus 5 Report post Posted February 11, 2007 about $20..go a new one that isnt stuffed already..it was the first part i ever bought for my e30! Quote Share this post Link to post Share on other sites
nz320i 0 Report post Posted February 11, 2007 whats wrong with s T fitting from para rubber? its what i used, about 2 dollars Quote Share this post Link to post Share on other sites
Nobimmer 694 Report post Posted February 11, 2007 Word.I'm using a 6mm (?) T that my dad uses for work. Give me a ring if you (or anyone) want one. a dollar each 0273206959 Definetly wont get narked on this time! Quote Share this post Link to post Share on other sites
gmccormack 0 Report post Posted February 11, 2007 whats wrong with s T fitting from para rubber? its what i used, about 2 dollarsThe factory part is not just a simple T fitting. Inside it are two one way valves that stop the water inside the hoses draining back down to the washer bottle. A T fitting will work in its place but there will be a much longer delay between switching the washers on and actually getting any water out. Quote Share this post Link to post Share on other sites
