allan
TV/Nav set up
had a crazy sunday B) idea and would like some feed back, trade me had an add for a tv/nav board computer video display4;3 for a e39 walnut etc,etc for about 4 hunde states about 5000 new what is involved to put one in a e39 that has not got one and what benifits would it have. :wacko: is this jochen area of x purr tees!!!!
Edited by allan
I saw what was for sale.
That is just the display and keyboard and tape deck.
You will also need:
Nav computer (not a ex-Japan one!)
TV tuner (optional)
CD changer (optional, can use existing if you have one)
Amp (can use existing if present)
Radio tuner
GPS antenna
Retro-fit wiring loom
Brackets nuts bolts etc
I've seen complete fits selling for around $3,000 to $4,000 NZD
You might be able to get it as cheap as $2,500 if you shop around and be patient
If all the parts are present, you can complete the install in a day. But that's probably pushing it a bit.
Make it a weekend to be sure.
Then you need to update the GM and SA code for your car as well.
Jochen
thanks for the break down on what is required for the Tv/Nav system is interesting what people try to sell. Might be alright but with him in Dunedin the item in Chch and the owner in Aussy seema a bit shady. thanks Jochen for the infor cheers Allan :unsure:
