naughty bmw
XYZ , BC, H&R Coilover comparisons / experiance
I knew I'd seen a distributor for the XYZs somewhere round here.
Do you have E46 gear yet?
Yes have E46 kits in stock now.
Have a set in our E46 and rides great!
Evan
Edited by Speedfactor Motorsport
Geoff was meaning the rear upper mount.
You can offset the top rear mount so to accomodate the rear spring diametre (of the complete coilover option) in the factory rear shock turrets.
If you were building a car and fabricating cage into it at the same time, you'd go the turret option.
Evan
Yep sorry about that. Posting threads after midnight is not a good idea. I could blame the moron who tightened the wheel lock bolts up so tight I had to drill them out or maybe a couple of beers. It's the rears that got changed.
We have some new and improved XYZ rear springs for the rear of E30 for the seperate shock / spring setup.
Its a stiffer rate than previously and spring length is only 110mm long.
These offer max lowering and are stiff enough to stop bottoming out.
Can be run in E36 as well. Spring rate is 670 lbs
Sits the E30 rear the same as Sascha picture.
Evan
Thanks Evan, Cheers for popping into this thread....!!
Can you contact me with a couple of prices for the separate rear spring and strut set up versus the complete coilover one please
My email is image.electrical@gmail.com or ph/text 021399248
I think the spring rates are looking pretty good paired with my 800lbs in the fronts.
Cheers.
Oh and yes, the stance on Sascha's car is very nice indead.
Can you also clarify for myself and im sure others on the site if the front struts in these complete kits are replaceable / rebuildable..? cheers
Cheers.
Will give you a call tomorrow to discuss some options, Thanks.
Been working pretty hard on the desired rear spring rate that suits the best stance and the occasional pasenger.
Will post some options shortly and clearify.
On the topic of repacement and rebuildable shocks from XYZ-Racing
We back up everything we sell across our range of performance and race shocks under the're normal expected, intended usuage, and carry a huge inventory of parts commonly expected to fail.
All the adjustable components are removable from the fully threaded shock bodies.
We supply assembled replacement shocks with different bump and rebound levels if need.
Dont hesitate to contact me regarding any queries on quality and reliability.
Thanks
Evan
Create an account or sign in to comment
You need to be a member in order to leave a comment
Create an account
Sign up for a new account in our community. It's easy!
Register a new account
Sign in
Already have an account? Sign in here.
Sign In Now
