Andrew
Bimmersport may go down.
A DNS server has crashed that will effect access to Bimmersport for the next 24 hrs. If you wish to able to access bimmersport please make the following changes to your computer.
Leaving your computer set like this may speed up access to Bimmersport also. So there is no harm in making these changes.
If using Windows
Click Start > Run - copy and past in:
C:\WINDOWS\system32\drivers\etc\hosts
Open the file in Notepad
It will look like the file below - copy and past in the sections about bimmersport.
# Copyright (c) 1993-1999 Microsoft Corp.
	 # This is a sample HOSTS file used by Microsoft TCP/IP for Windows.
	 # This file contains the mappings of IP addresses to host names. Each
	 # entry should be kept on an individual line. The IP address should
	 # be placed in the first column followed by the corresponding host name.
	 # The IP address and the host name should be separated by at least one
	 # space.
	 # Additionally, comments (such as these) may be inserted on individual
	 # lines or following the machine name denoted by a '#' symbol.
	 # For example:
	 #	  102.54.94.97	 rhino.acme.com		  # source server
	 #	   38.25.63.10	 x.acme.com			  # x client host
	 127.0.0.1	   localhost
60.234.73.102 www.bimmersport.co.nz
60.234.73.102 bimmersport.co.nz
For Apple/Linux users - you should know how to do it anyway.
But the hosts file should be located in:
/etc/hosts
so as the root user - open your favourite text editor and make these changes. In my case
$su
$nano -w /etc/hosts
and should look like
127.0.0.1		localhost
   127.0.0.1		hostname
 ::1	 ip6-localhost ip6-loopback
   fe00::0 ip6-localnet
   ff00::0 ip6-mcastprefix
   ff02::1 ip6-allnodes
   ff02::2 ip6-allrouters
   ff02::3 ip6-allhosts
all fixed now .. with this appology from the domain house ..
Unscheduled Outage at DiscountDomains.
Dear Josh,
As you may have noticed, DiscountDomains experienced an unscheduled outage this morning in our data centre that would have caused intermittent problems connecting to the servers hosted here.This would have affected websites, email and DNS services.I sincerely apologise for any disruption this may have caused to your business, and we are confident that the issues
have now been resolved and all services should have returned to normal.We will be performing a full review of what happened, along with any changes that may be required to our infrastructure to prevent a recurrence of this outage.At this point we are contacting you to inform you of the latest developments, and we will certainly follow this up with more detail once we have completed the review.Should you have any further questions, please do not hesitate to contact our support
team.
Kind Regards
Sam McNeill
DiscountDomains Operations Manager
what? they personally addressed a letter to me to! I think it may be the same one :D
