phtbmr 0 Report post Posted April 16, 2007 Im after a bit of help Im looking for a gearbox to suit the 1.1 motronic ignition which has the mounting holes for the speed and tdc sensors, along with the sensors, and a flywheel with the lug in it, Thanks malcolm Quote Share this post Link to post Share on other sites
Andrew 30 Report post Posted April 16, 2007 Im after a bit of help Im looking for a gearbox to suit the 1.1 motronic ignition which has the mounting holes for the speed and tdc sensors, along with the sensors, and a flywheel with the lug in it, Thanks malcolm Hi Malcolm - Motronic gearboxes don't need any sensors in them. Motronic gets RPM (from a HT lead), CAS/TDC is on the front of the motor. L-Jetronic gearboxes have all those sensors in them. So in your case (if you have motronic) - then either gearbox will work for you. Quote Share this post Link to post Share on other sites
ED1RTY 2 Report post Posted April 16, 2007 Also, you can get the sensors from the stealer. You can also get a tap and dye set from Mitre 10 Mega etc. The gearboxes should have the blanks for the sensors even if they dont have the actual sensors. You can just tap the sensors into the blanks. A mate of mine did this with his Dogleg when he did the ignition swap. Quote Share this post Link to post Share on other sites
smokenbaby 0 Report post Posted April 16, 2007 Motronic gearboxes don't need any sensors in them. Motronic gets RPM (from a HT lead), CAS/TDC is on the front of the motor. L-Jetronic gearboxes have all those sensors in them. So in your case (if you have motronic) - then either gearbox will work for you. I would beg to differ. It took me almost a year to find a gearbox for my '87 2.5 conversion. It is Motronic not L-Jetronic. I went as far as building a jig so I could cut the sensor ports out of an auto bellhousing and weld into my 320 gearbox. '87 325's are the only model that run these gearbox sensors for RPM and TDC. I have done alot of research on this and found that even if you find a gearbox with blanks in the bell housing it is very important that you drill the sensor holes in the exact right place or the car will run like a sack of sh*t. Your best bet is to find late model 325 injection , comp and wiring. That way you can run the crank angle off the front and the RPM how ever it gets it from late model. Quote Share this post Link to post Share on other sites
ED1RTY 2 Report post Posted April 16, 2007 I have done alot of research on this and found that even if you find a gearbox with blanks in the bell housing it is very important that you drill the sensor holes in the exact right place or the car will run like a sack of sh*t. Tried and Tested. Worked for us Quote Share this post Link to post Share on other sites
will 169 Report post Posted April 16, 2007 Hi Malcolm - Motronic gearboxes don't need any sensors in them. Motronic gets RPM (from a HT lead), CAS/TDC is on the front of the motor. L-Jetronic gearboxes have all those sensors in them. So in your case (if you have motronic) - then either gearbox will work for you. Andrew, Motronic 1.1 uses sensors on the bellhousing, l-jetronic uses the distributor so doesn't need sensors. Motronic 1.3 uses the sensor on the crank pulley and one on the ht lead. Will Quote Share this post Link to post Share on other sites
MattA 165 Report post Posted April 16, 2007 Maybe I'm wrong but I didn't think they made 2.5ltr with L-Jet? cheers matt Quote Share this post Link to post Share on other sites
phtbmr 0 Report post Posted April 21, 2007 thanks for all your feedback guys i have been a way for that last week and had no internet, if i could not find a gearbox this will be the way i go around it find late model 325 injection , comp and wiring. That way you can run the crank angle off the front and the RPM how ever it gets it from late model. Quote Share this post Link to post Share on other sites
HELLBM 1697 Report post Posted April 22, 2007 Have everything you need. ph.0212435526 Regards Ray Quote Share this post Link to post Share on other sites
Guest Denny Crane Report post Posted April 22, 2007 To add to this, can an '85 g260 be used on a car currently with a '90 g260? Quote Share this post Link to post Share on other sites
Andrew 30 Report post Posted April 22, 2007 To add to this, can an '85 g260 be used on a car currently with a '90 g260? Yes Quote Share this post Link to post Share on other sites
bem-on 0 Report post Posted April 23, 2007 (edited) i have a box for you but thats it no other bits. its in palmy but im in wellington but if you are keen il sort you out call 021 2983279 Edited April 23, 2007 by bem-on Quote Share this post Link to post Share on other sites
